Bryan at pcm forless
Old Dec 23, 2005 | 10:52 PM
RICEFEDZ28's Avatar
I have a 96 z28 the mods are as follows votech s trim 9lbs. boost, hooker long tubes, comp cam 224/230 .510 lift, gm 1.6 roller rockers, lt4 intake, adding a spearco air to water intercooler, 3.73 gear, slp loud mouth exhuast, removed air pump, egr, and rear o2's, can you tune my pcm or should i switch over to a obd1? how much and how long would it take?oh i also had larger valves put into the head but can't remember the size.
Old Dec 23, 2005 | 11:06 PM
DarkHorse's Avatar
Re: Bryan at pcm forless
Yes he can tune OBD2 cars
He'll be coming to Ohio in early spring for dyno tuning - check the NE section.
Old Dec 24, 2005 | 12:31 AM
Alvin@pcmforless.com's Avatar
You really ought to email this question to him
His email is programmer@pcmforless.com
Old Dec 24, 2005 | 08:13 AM
RICEFEDZ28's Avatar
Ok thanks.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
