Need Help with 02 / Fuel Inj Pulse problem
Old Dec 13, 2005 | 06:54 PM
edfiero's Avatar
Please take a look at the scan in the attached link, of my new 383 LT4 Stroker. (OBD II) I don't know how to correct this inbalance between the left and right bank.
http://members.localnet.com/~jteague/SCAN47.xls
Throttle Position voltage is .68 at idle
Vacuum is good. Haven't been able to locate any vacuum or exhaust leaks.
Plugs and Wires are new. Tripple checked they are all hooked up to the correct cylinders.
Fuel Pressure is in the mid 40's at idle
Injectors have all been flow tested and are within 2% of each other
02 sensors are new, AND I've tried switching right and left sides and the problem does NOT move with the sensor.
Although not shown in this scan IAC counts are in the low 40's at idle.
Any suggestions would be appreciated.
Old Dec 15, 2005 | 07:07 PM
Doc99SS's Avatar
Re: Need Help with 02 / Fuel Inj Pulse problem
Dont even bother to log the S2 O2 sensors, they are worthless for info.
I would see if it is the O2 sensors first of all. Swap the front O2 sensors side to side and re-log. If the LTFtrims follow the O2 swap, then the O2s are a bit too different in performance. You could then try the rear O2s in the front positions, do this in an attempt to identify two O2 sensors which are close in performance,,, a 3 to 4% difference can be expected.
Old Dec 16, 2005 | 10:51 AM
edfiero's Avatar
Thanks. I swapped the sensors and the problem did NOT follow.... its still there on the original side.
Old Dec 16, 2005 | 12:34 PM
Doc99SS's Avatar
Good.. Then most likely, the higher flowing fuel injectors are stack on one side. Try fuel injector cleaner for awhile, that could help. If that has no effect, you should consider to have the injectors cleaned and flow tested. If you do that, then evenly disperse the flow rates so they are evenly match side to side. BTW: find out which cylinder tends to run the leanest and put the highest flowing injector in that hole.
Old Dec 16, 2005 | 12:53 PM
Doc99SS's Avatar
I am sorry, I never read the bottom part of your initial post. You have done everything that I suggest. However, if the injectors were marked with a number and you still can identify the 4 highest flowing injectors, then stack them all on one side, apparently, stack them on side 2, the pass side.
Old Dec 19, 2005 | 10:06 AM
edfiero's Avatar
Thanks Doc.
Attached is a scan of my car, if this might give you any additional insight into my problem.
http://members.localnet.com/~jteague/SCAN3a.xls
RUENUF
Mar 13, 2016 03:39 PM
Zee man
Feb 12, 2015 07:07 AM
Scottyboy
Feb 11, 2015 10:28 PM
nophix
Nov 30, 2014 10:26 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
