Computer Controlling Only Fuel
Old Nov 29, 2005 | 06:09 PM
95Zedder's Avatar
Is it possible for the stock computer to only control the fuel and not ignition so I could still use the lt4 intake and have a distributor in the back?
Old Nov 29, 2005 | 11:01 PM
Re: Computer Controlling Only Fuel
You could run the ignition off a distributor, with its own centrifugal and vacuum advance. You would still need the optical sensor in the Opti to feed the cam position to the stock PCM. It needs the low res pulse to fire the injectors in the correct sequence. It will not run without the low res pulse.
DirtyDaveW
Dec 1, 2016 05:37 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Jul 4, 2005 05:00 PM
ScottZ
Mar 3, 2004 01:34 PM
