1996 PCM question
Old Jan 30, 2006 | 02:13 AM
RedHottG2's Avatar
1996 PCM question
If I was to do a A4 to T-56 swap in a 96 Z28 would I need to use a 96 OBD11 M6 PCM or can you do some kind of programming to the A4 PCM to make it work ? If I need to swap PCM's would a 96 be the only one that will work or would a 97 also work ?
Old Jan 30, 2006 | 09:01 AM
Re: 1996 PCM question
Any of the mail-order tuners can program your present PCM for the M6.
Old Jan 31, 2006 | 12:15 AM
kingslam's Avatar
dude you can send your PCM to member tjwong on here and he can program it for you cheap! I own a shop and he does my programming for several years now, he has a dyno too so his programs are all tested!
oldschool
Feb 9, 2016 09:21 PM
Jan 5, 2015 07:14 PM
Jazsun
Dec 29, 2014 12:14 PM
siguy
Nov 27, 2014 10:07 AM
