Setting up with Hpertech tuner
Old Dec 10, 2005 | 09:43 PM
ur jlus's Avatar
I have a '02 Z28 vert with ram air, k&n, lid, bellows and a flowmaster. Now the question, what rpm and shift speed should I set with my hypertech tuner. Oh yea 2.73 gears if that makes a diff.
Old Dec 12, 2005 | 12:26 PM
Z28_95RIDE's Avatar
Re: Setting up with Hpertech tuner
If you mean mph change for your automatic, I can tell you the affect of -6 mph (about 600 rpm) difference for 1-2 shift. The car transfered a lot of rubber to the asphalt at WOT. LT1s are champs at low rpm torque and shifting 600 rpm sooner makes the gear change more dramatic. Your LS1 makes even more torque but higher up in the RPM range.
Frank Cahall says the 4L60E line pressure begins to drop off after 5000 rpm. Shifting sooner at WOT will put your car closer to the max torque curve with a more definate jolt with the shift. I doubt it will give you a better ET but will be a load fun on dry, straight pavement if nothing breaks.
Regards
Old Dec 12, 2005 | 07:40 PM
ur jlus's Avatar
Regards
If nothing breaks?
DirtyDaveW
Dec 1, 2016 05:37 PM
blac94Z
Apr 12, 2015 04:48 PM
383TransAm
Parts Wanted
Feb 15, 2015 05:05 PM
tubby
Oct 13, 2003 09:16 AM
CamaroZBoy
Aug 19, 2002 12:41 PM
