any scan tools
Old Jan 17, 2006 | 01:03 PM
red 95 z28 lt1's Avatar
any scan tools
i was wondering if there are any cheap or inexpensive scan tools that will pull up codes on my car its obd1 but with the obd2 connector. the only one i know of is the snap on scanner that goes for over $2k. I also have a madz28 tune as well
Thanks Frank
Old Jan 17, 2006 | 01:18 PM
jsetzer's Avatar
Re: any scan tools
Do you have an interface cable?
Old Jan 17, 2006 | 01:47 PM
Re: any scan tools
no i do not
Old Jan 17, 2006 | 02:06 PM
jsetzer's Avatar
Re: any scan tools
IF you can convince autozone or someone that has an OBD1 scanner to let you do this, you can use some pieces of wire to connect the scanner to the correct pins on the OBDII connector. The only thing preventing one of their scanners from working is the shape of the new plug. Some people have actually chopped it off and put an obd1 plug on it.
Search on here for pinouts of the 1 and 2 connectors, then just use wires to jumper to the proper points.
Another idea would be to find an OBD1 connector from a 94, and splice it in under the dash so you have both style plugs....
Old Jan 17, 2006 | 02:18 PM
Re: any scan tools
sounds good but if i had an interface cable what would that do?
Old Jan 17, 2006 | 02:20 PM
jsetzer's Avatar
Re: any scan tools
You could plug it in to a pc or laptop and use something such as freescan (which is free) to monitor everything and pull codes. If you are thinking of buyint anything thats a good place to start, then you won't have to mail you pcm off to get the tune reflashed either.
AKM Cables
Old Jan 17, 2006 | 02:24 PM
moparman's Avatar
Re: any scan tools
Check these refurb units. You'll also need the correct cable.
www.autocheckup.net/Refurb.htm
Old Jan 17, 2006 | 03:06 PM
Re: any scan tools
Thanks Frank
Autoxray and Actron are just of couple of readily available brands of scanners that will work on your car. Just make sure you get the correct cable for your 1995.
Old Jan 18, 2006 | 12:26 PM
oneslowz28's Avatar
Re: any scan tools
get a cable from moates.net i just got mine in today and this thing is verry well built. i have used it 2 times already and love it.
Old Jan 19, 2006 | 03:13 PM
Re: any scan tools
thanks for all the help
Old Jan 20, 2006 | 01:25 AM
67fso's Avatar
Re: any scan tools
Download TTS Datamaster for your 95:
http://www.ttspowersystems.com/DM_Software.htm
Buy a cable for your 95:
http://www.aldlcable.com/sc/details.asp?item=aldlobd2
$40 total cost and you're set.
marlar98
Sep 12, 2018 07:18 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
KYWes
Sep 26, 2015 08:49 AM
plattted
9
Sep 20, 2015 11:23 AM
tommalcolm
Sep 11, 2015 03:39 PM
