Bank 1 Lean only at idle??
Hello all. First off this is what is going on. Only at idle, the drivers side (left bank) o2 sensor states the car is running lean 160-170 blm. Drivers side is fine 125-133 blm. I have a y pipe from a 1996, so it has locations for four o2's, although my car only runs with two being that its a 1995. In place of the driverside rear o2, I have a wideband o2 sensor, and on the left side(passenger), just a plug. Being that the right side regular o2 states its running lean 160-170 blm, the wideband 02 states 13.1-13.4 AF, so if indeed the car is running lean, the o2 is doing its job and correcting the lean condition. Keep in mind the o2's are brand new. I have looked for exhaust leaks, none are present. I dont know what else to do as far as fixing this situation. Thank You BTW I have logs and all for anyone who cares to view. Thank You once again...
Nayr
Mar 3, 2023 08:34 PM
tdigger9899
Sep 7, 2015 10:56 AM
zajones
Jul 30, 2015 02:18 PM
Noct
Jul 14, 2015 01:18 AM
