ALdl connection problems...Please help..
Old Nov 5, 2005 | 12:26 AM
nybroker00's Avatar
I have a laptop computer with a card to make a serial port. The card automatically goes onto com 5. I try to hook the laptop up to tuner cat, but it says cable failure. I tried to hook it up to my home computer and got the message: "No respronse from pcm" exactly like that. I am trying to tune my 1995 camaro. This car was a v6 swap. I put a cam xfi 268 hr- 13. It is .570 .565 and the duration @.50 is 218/224. I have not done anything to the computer yet. The car doesn't run by itself and it backfires if I rev it up or when the idle falls and shuts off right away. I get the headers #2, #8 , #3, #5 get very hot and smoke the header wraps after like 10 seconds. I believe i am running too leam and the car is gasping for fuel am I correct? I also have tried adjusting the valve like 4 times already i believe they are correct. What should I do i am so lost from here. If anyone could be a lifesaver i would deeply appretiate it.
Old Nov 5, 2005 | 06:37 AM
rsjay's Avatar
Re: ALdl connection problems...Please help..
I seem to be having a similair problem. I swapped a 1994 LT1 motor in my 94 V6 camaro also. I put a hotcam and 1.6rr in my motor and had the computer programmed by pcmforless. Mine is idling around 500rpm and I have to keep the gas on it for it to continue to run. Mine also backfires. I just received my ALDC cable yesterday and will try and hook up. What program are you using?
Old Nov 5, 2005 | 08:25 AM
nybroker00's Avatar
i am trying to use tuner cat. I was going to try pcm for less. so that didnt work for you. The connection is driviong me nuts i dont want to pay for computer tuningwhen i have the program. The only thing left i can think of is changing the fuel pump. I thinnk its on a different volume . i have been reading this from other guys.they say from v6 to v8 you have to change the fuel pump. Thats my next try. Also our fuel lines are smaller so i dont know of that will make a difference. I noticed on factory z28's they use a hose instead of the plastic lines and they seem to be bigger. and i used to have a third line on the v6 from the purge canister but now i dont know where to put it.
Old Nov 5, 2005 | 11:32 AM
rsjay's Avatar
I've talked to a couple guys and they said you shouldn't have to change the fuel pump but I can't say for sure. Would be nice to know and anyone can answer this for the both of us??
Old Nov 5, 2005 | 07:00 PM
infinitebird's Avatar
Do you have the right com port selected in tunercat?
Old Nov 5, 2005 | 10:57 PM
nybroker00's Avatar
i have tried changing the com port several times. And I also tried to change it om my devise manager. I dont know what else to do. I tried for hours going back and fourth. I have the cable connected acording to the instructions that came with the aldl. and i bouth the pcmmia card that gooes from the laptop to ethernet to serial cause my cpu doesnt have a serial port. i also tried bringing my home computer outside and got the same message. "no respronse from pcm".
Old Nov 6, 2005 | 07:46 PM
Hotwire's Avatar
wouldn't happen to be a newer dell laptop would it? I had purchased one 2 yrs ago, come to find out they were having problems w/ the texas instruments bridge circuitry, found that out on dells forum. sent it back and got a hp.
I'm not saying this is true, just what happened w/ the model I had purchased. Tried usb to serial adapters, several different kinds from cheap to really expensive, tried pcmcia adapters with also no luck.
akmcables has a usb connection now if you wanted to go that route. www.akmcables.com
good luck,
Jeff
Old Dec 5, 2005 | 06:23 AM
Hotwire's Avatar
was visited posts I've been to in the past and came across this one. What aldl cable are you using? If it is a mastach cable, do a search, I had purchased one and it didn't work, but I found out how to make it work flawlessly.
Old Dec 24, 2005 | 03:38 PM
hallbilly's Avatar
http://www.aldlcable.com/
I have one of their cables... Hotwire what did you do to fix yours to work flawlessly? As I also have a dell inspiron 8600 from 03 i think... I can read data most of the time but here lately i am having some connection problems
Old Dec 24, 2005 | 03:49 PM
Hotwire's Avatar
not sure if the aldlcable is setup the same way, but on mine the translator was powered by the serial data port on the laptop, my laptop wasn't supplying the needed voltage, so I pulled power from the aldl port to the regulator on the board, works fine now.
Old Dec 24, 2005 | 05:04 PM
hallbilly's Avatar
K thanks, I cant figure mine out... i can get it where datamaster and freescan work everytime i try... but whenever i try to read or load a tune to the car it will not work!
And is the fan supposed to kick on when its doing this?
Old Dec 25, 2005 | 01:24 PM
Some people have had tuning problems with the aldlcable.com cable, like here: http://web.camaross.com/forums/showthread.php?t=388844
But it seems to work for others, which is odd.
Old Dec 25, 2005 | 05:58 PM
hallbilly's Avatar
Hmm, that is weird...
Old Dec 25, 2005 | 08:45 PM
Hotwire's Avatar
I don't know how aldl has their boxes setup, but if you can get into it w/o destroying the case I can offer looking at it for you, would just ask that you send along enough money to pay for return shipping and maybe a couple dollars for time/gas. If not, I can still look at it, but will have to mess up the case to get to the circuit, mastach had their lids superglued shut.
I would suggest doing a search and checking to see if changing port settings would help you out before going my route. All I really did was check the board for correct connections, then tested voltage and found my problem.
Nayr
Mar 3, 2023 08:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
drt
Sep 27, 2015 04:39 PM
marlar98
Sep 19, 2015 07:53 AM
