fuel gauge!
Old Dec 11, 2005 | 01:08 AM
jalb's Avatar
fuel gauge!
im not sure if this is the right place to post this thread but i do know that it is controled by the computer,,,,my fuel gauge is bouncing slowly on a cold start,,i rememberd i only had a 1/4 of a tank when i parked my 2000 z28 but this morning it was reading full and it was bouncing back and forth a little,,is this a problem????
Old Dec 17, 2005 | 01:00 AM
Critter's Avatar
Re: fuel gauge!
yes
Old Dec 19, 2005 | 07:20 PM
rkinney's Avatar
Re: fuel gauge!
Gm has issues with their level sensors. I just got a bulletin the other day at work about a new fuel treatment that helps keep the sulfur in fuel from damaging the sender card. You might want to try that. (Don't know if it actaully works). If not it could be your level sensor needs replacement.
Old Dec 22, 2005 | 12:43 PM
Hotwire's Avatar
Re: fuel gauge!
get a can of Sea Foam from NAPA. Read the directions and run it through the system, works great as a top end cleaner and fi cleaner through the tank.
Garcia5
Jul 7, 2022 06:51 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
T-REX
May 14, 2002 08:47 PM
