low load bucking
Old Dec 20, 2005 | 12:04 PM
Deenasty's Avatar
low load bucking
Im having a problem where if im under 2000 rpm's in any gear(usually 2-6) under slight acceleration im getting "bucking". Im constantly having to downshift my m6 to avoid this bucking. Is this a timing issue?
Old Dec 23, 2005 | 12:58 PM
Ricardo's Avatar
Re: low load bucking
I was only able to get rid of the problem by switching over to open loop.
It got even better after changing the injector offsets to the appropiate ones.
It made an unbelievable difference in driveability.
RG
Old Dec 23, 2005 | 01:14 PM
Deenasty's Avatar
RG
Ricardo, de que tamanio son tus injectors? Are you using lt1 edit or tuner cat?
Old Dec 23, 2005 | 09:46 PM
Ricardo's Avatar
I´m using Accel 30# Injectors.
I know there have been a lot of posts regarding them, but mine do not leak and work just fine in open loop.
I do my tuning with LT1 edit.
A wideband is strictly necessary for a good open loop tune.
RG
Old Dec 24, 2005 | 01:55 PM
Deenasty's Avatar
RG
Im running 40lb SVO's. I have lt1 edit, and I have a wideband in the car. Is it possible to send me your file, so I can take a look, and get some hints? Deenasty83@comcast.net
Old Dec 30, 2005 | 03:12 PM
mycarisfasterthanyours's Avatar
I would also like a copy of that file if you could please email me. mycarisfasterthanyours@hotmail.com Thanks!
Old Dec 30, 2005 | 04:51 PM
blkchevyz's Avatar
how much timing are you running around 2k
how bigs the cam?
Old Dec 30, 2005 | 07:18 PM
Deenasty's Avatar
how bigs the cam?
cam is pretty big, and im running a tad bit more than stock..
Old Jan 3, 2006 | 10:21 AM
blkchevyz's Avatar
if you have a data log, and your ecm file email it to me, not sure how much help i'll be but i will take a look.
Old Jan 3, 2006 | 11:07 AM
Deenasty's Avatar
awesome, I will get that to you a.s.a.p!
KYWes
Jun 14, 2022 06:52 AM
silvermansteve
Mar 4, 2015 05:02 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
97Z28Muscle
Feb 6, 2015 10:44 PM
Alex Barnes
Jan 24, 2015 10:21 PM
