pcm forless???????
Old Dec 18, 2005 | 06:44 PM
nightrider93's Avatar
pcm forless???????
where does this chip install??? i keep hearing about these mail order tunes how hard is the install.
Old Dec 18, 2005 | 07:09 PM
cpt_bimes's Avatar
Re: pcm forless???????
i take it you have a 93 car?
I'm not completely sure, but i think it installs in the back of the pcm.
Old Dec 18, 2005 | 07:22 PM
yea sry bout that it is a 93 camaro where does this exactly install in the pcm under the hood by the firewall??????????????????????? or somewhere else that i dont know about.
Old Dec 18, 2005 | 09:21 PM
cpt_bimes's Avatar
yeah ..the pcm is located by the passenger side fender under the cowl. I think it installs somehow into the pcm.
maybe somebody else will chime in.
Old Dec 18, 2005 | 10:05 PM
Alvin@pcmforless.com's Avatar
If you send me a email (chips@pcmforless.com) i'll send you a pdf copy of the install instructions that way you can get an idea.
Old Dec 18, 2005 | 10:58 PM
danhr's Avatar
first you drain the blinker fluid, rotate your driveshaft, and balance your muffler
or they will send you the file and you can load the software into your pcm, providing you have the cables (which cost extra money)
or you can pay the core charge and they will send you a pcm with the tune already in it, you replace your pcm with the one they sent you adn send them back your old one and u get your core charge back minus $10.
Old Dec 19, 2005 | 03:57 AM
Slow260z's Avatar
Funny post unless of course you read he has a 93, and know that his ECM uses EPROMS.
I guess you were overfilled with fluids or wrapped around the axle when you replied to this post eh
Old Dec 19, 2005 | 02:40 PM
GOOD ONE I TOLD A FRIEND WHO IS NEW TO THE FBODY WORLD TO CHECK HIS ALTERNATOR FLUID AND HE STARTED LOOKING KEEP IN MIND HE HAS A HORRIBLE TATTOO OF TWO PISTONS CROSSING A SKULL. IT WAS CLASSIC.
ALVIN PMD YA.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
