Autozone can't scan my 95?
Old Nov 21, 2005 | 12:18 PM
Camarorob1997's Avatar
I thought there generic scanner would work as long as they have a gm 16 pin.
Well I'm looking at http://www.autocheckup.com/ and what would be the best scanner/cheap that can scan obd1/ obd1 16 pin/0BD2.
Let me know your guys opinions.
Thanks Rob
Old Nov 21, 2005 | 02:28 PM
kingslam's Avatar
Re: Autozone can't scan my 95?
Yup, go here and click on the 94-95 LT1 Edit> http://www.carputing.com/
You can get their free scan software, then buy a interface cable for a laptop.
If your unsure of yourself best bet is to find a LT1 Editing guru on here that is close by and go visit him. There are some real good tuners on here, like tjwong or madwolf and more!
They have really helped me out a lot and I own a custom shop!
Wish they would come work for me!
I buy them a Dyno!!!
Old Nov 21, 2005 | 05:21 PM
Well thats a different route also, I do have a basic laptop.
The reason I wouldnt mind a scanner is I can do more then just my car, cause I do work on other poeples cars friends/family and this would be a great dianositc tool.
Any suggestioins on scanners guys?
Old Nov 21, 2005 | 08:23 PM
Z28barnett's Avatar
Many of the '95 have OBDI system with a OBDII connector plug. If autozone tried and OBDI connector won't work, same is true with a OBDII scanner, right plug but not the right sytem.
Moates cable USB has worked for me. If you get that and Freescan, then you can scan your own car and opens the door for cheaper PCM tunes.
Good Luck
Z28
Old Nov 21, 2005 | 08:46 PM
ALL 95's are OBD-I PCM with a 16-pin OBD-II style ALDL connector.
Outfits like Auto Xray and Actron make optional 16-pin OBD-I connectors for their scanners. You can also use a scanner with a 12-pin connector, and use jumpers, as outlined on Shoebox's website:
http://shbox.com/1/xraycable.jpg
Old Nov 22, 2005 | 09:46 AM
http://www.autocheckup.net/Merchant2...tegory_Code=RF
THis one says it cmoes with the gm 16 pin OBD1 cable and plus all the rest that I would need.
Old Nov 22, 2005 | 10:23 AM
97WS6Pilot's Avatar
AutoXray is pretty good too. Edit: Didn't see the link above. It is AutoXray
Old Nov 22, 2005 | 12:45 PM
IM probally going ot pick that up, I can scan more then just my car and that is a plus.
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
plattted
9
Sep 20, 2015 11:23 AM
tommalcolm
Sep 11, 2015 03:39 PM
