spark retard and CCM questions
Old Nov 20, 2005 | 05:06 PM
Paul94Z's Avatar
Someone mentioned a while back about the tranction control/ spark retard request and possibly using it for nitrous retard.. has that thought gone anywhere? I'm also curious about the vette 333 PCM and its ability to interface with a CCM? what exactly is its function? One more random thought.. can any of the unused outputs be used as an ECM controlled shift light? maybe the skipshift lamp?
Old Nov 22, 2005 | 09:31 AM
Physics's Avatar
Re: spark retard and CCM questions
I've heard of multiple people using the traction control spark retard for a nitrous retard. You just have to have a switch in the car that enables the "traction control". From shbox's site, it looks like you need to ground pin A23, which is orange/black on traction control enabled cars. From my understanding, you will not have that wire and will need to connect directly to that pin. You can then use C11 to turn your nitrous solenoid on.
Old Nov 24, 2005 | 04:24 AM
Paul94Z's Avatar
very interesting.. how much timing does it actually pull? well I half way answered my last question.. I found the "Traction Control Spark Retard vs RPM" in Tunercat. I've heard pull on average 5 deg per 100hp shot? Is this correct? so in theory I would fill all RPM values with 5 deg? Or maybe there should be a curve on it? I will most likely use the LJO programmable progressive controller so I could copy the spark retard curve with the curve on the N2O controller. Any ideas on the other questions?
Old Nov 25, 2005 | 07:08 PM
Paul94Z's Avatar
do the 93 ECMs have the Traction control/spark retard option?
mikey4play
Mar 15, 2015 11:45 AM
jasonduaine
Mar 7, 2015 09:44 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
nophix
Nov 30, 2014 10:26 PM
