can't read pcm
Old Dec 8, 2005 | 11:19 PM
creed1062002's Avatar
can't read pcm
I just purchased a cable form aldlcables.com and a program from bryan herter, and I am unable to get it to read the pcm. I also tried a program called free scan and it worked perfect so I know the cable is working. Also i was trying to use the tunercat windows version of the programmer. Any ideas or suggestion would be greatly appreciated.
Old Dec 9, 2005 | 07:39 AM
Re: can't read pcm
This really belongs in the computer/diagnostics forum, but sounds like you might need to look at setup options in your programs that don't work.
Old Dec 9, 2005 | 09:02 AM
Re: can't read pcm
A couple of helpful hints on posting:
-include the basic data on your car... particlualry the year. Not all LT1 years (I'm assuming you have an LT1 since you posted this on "LT1/LT4 Engine Tech") are the same, nor are the PCM interfaces all the same.
-post on the correct forum.... I'll move this to "Computer Diagnostics and Programming" for you.
Old Dec 9, 2005 | 09:05 AM
Re: can't read pcm
Ok its a 94, very light mods for now, just a 52mm throttle body, underdrive pulleys and 4.10 gears, also it has the 12 pin obdI connection.
Old Dec 9, 2005 | 05:42 PM
Re: can't read pcm
Anybody? I changed the pcm today still have the same thing. Also tried my friends computer he uses to program his car. Still the same thing.
DirtyDaveW
Dec 1, 2016 05:37 PM
ad356
Apr 22, 2015 08:35 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Jazsun
Dec 29, 2014 12:14 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
