stroker
Old Sep 25, 2002 | 02:26 AM
stevem's Avatar
stroker
where can i get a crank with a 4 inch stroke for my L98?
how do you get 396 out of a small block?
what mods do i need to do?
THANKS
Old Sep 25, 2002 | 08:21 AM
kmook's Avatar
Advanced Tech Moderator
Hey Steve,
I will move your questions over to 3rd Gen Tech, as true they are stroker related, but they arent too advanced...
Thanks Bud!
Old Sep 25, 2002 | 12:38 PM
Fast3rdGen's Avatar
that i know of.....you can't put a 4" crank in a production block with out filling the block an inch or two with jacket filler. BUT....a 396 uses an offset ground 383 crank which comes out to 3.85 stroke. the rod length is your choice just remember that with long strokes and long rods you get really thin ring lands and low compression height. from what i've seen with all aspects being the same....the extra .1" stroke is only worth a couple hp and same for tq. although cool factor would be sweet in making a 1st gen small block SS396 or the same with a nova. i'd say either go a healthy 383 od 400....you'll spend less money and prolly be alot happier. not to mention it'd prolly last longer as well.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95craz28
11
Sep 12, 2015 07:47 AM
Cbr02
Aug 23, 2015 10:55 PM
TGGodfrey
Aug 18, 2015 06:08 PM
