LCA/Panhard Install
Old Sep 18, 2002 | 05:16 PM
RadarRunner's Avatar
LCA/Panhard Install
When I install my new LCA & Panhard, should I jack the back of the car up using the jacking points or jack under the axle?
Old Sep 18, 2002 | 05:50 PM
Demon Z28's Avatar
jack it up by the pumpkin, put jackstands under the frame (not the rearend), drop it onto the jackstands, then keep the jack under the rearend and drop it just far enough so you can unbolt the parts you need to replace and call it good (I'd recommend starting one LCA at a time then do the panhard bar last)
Old Sep 18, 2002 | 08:32 PM
TheGreatJ's Avatar
Demon has it right...stands under the subframe and jack under the pumpkin....you need to be able to shift the rear up and down to take tension off the LCA and PHR bolts so you can get them out and back in.
Old Sep 18, 2002 | 10:53 PM
Thanks guys! Just got done & put everything up & it wasn't too bad. Normally if it is a 30 minute to an hour job, something will not work right with my luck & it'll take 3 hours.
Thanks again!
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
