Now What?need Help Very Very Fast.
i have a post already about my car backfiring on me.well today i fixed that.it turned out to be my timing.anyways after i got the car running good, i go to close the hood and as soon as it closed the car started running like it had lost 2 cylinders. well guess what! it lost all 4 on the drivers side.so i put a diode tester on my injectors and i get a very dim light and it dont flash at all.so its getting very little power, and its not enough to open the injectors right???????. as far as i can see i dont see any fried wires or any loose connections but ill keep on looking.i hope someone had the same problem and can help me out here.im a student at U.T.I. in glendale heights il. and i cant afford to miss class.they are very strict about that crap.but help would be greatly appreciated.
UTI tuition
I've been considering going to thier Ca campus but I can't seem to find out how much the cost is. Can you give me some idea? The last figure I saw was in the 20-30k range for the full course. That just sounds like too much to me.
Re: UTI tuition
May 15, 2015 10:43 AM
Just check them both and make sure the metal strip that you can see through the fuse isn't open. can't miss it.
