Extra Capacity Tranny Pan, Worth It?
Old Sep 29, 2002 | 01:57 PM
rickyzZ28's Avatar
Just like the topic says is it worth it? My stock pan is will not quit leaking (I think it is bent) so I am just going to get a new pan. Also does anyone know where I can get new bolts as well?
Old Sep 29, 2002 | 09:32 PM
TheGreatJ's Avatar
A high-capacity pan will help keep the trans cool, which for a 700-R4 is a very good thing. It's gonna cost a little ground clearance (depending on which one you get) but it's definitely better than a stock pan.
Bolts you can find at any hardware store.....just take an old one with you to match 'em up.
Old Sep 30, 2002 | 01:34 AM
chevy qc's Avatar
i deffinitly recomend the deeper transmission pans. i've found the transmission fluid temps are actually lower with a deeper pan than using an average size transmission fluid cooler. i've been doing alot of testing with the 700r4, 4l60, and 4l60e's over the last 2 years with my own and other's i've worked on/built and found the deeper pan is one of the best mods of any.
Old Sep 30, 2002 | 01:42 PM
87DJP2001's Avatar
If you already bent your Pan and it is leaking, I would be cautious about getting a deep tanny pan. If you insist, make sure it is stamped steel and NOT Cast Aluminum. Reason, Steel will bend and the cast aluminum will crack ( major fulid loss). Just some advice. There are PRO & CON on this subject.
94Form
Jul 17, 2015 10:56 PM
SergheiS
Jul 5, 2015 03:27 AM
VF-124
Mar 16, 2015 08:14 PM
