Is there a difference in fenders between 82-90 & 91-92?
Old Oct 7, 2002 | 06:55 PM
Tobe2wild's Avatar
If there is a difference what is it? Derek
Old Oct 7, 2002 | 07:23 PM
91RS_Rider's Avatar
well
There shouldn't be any differnce in the fenders accept for the ground effects. those should be the only differences that they have... the 90-92 have the kinda rounder and longer ground effects while the earlier ones have shorter ground effects if any at all.
Old Oct 7, 2002 | 07:26 PM
rickyzZ28's Avatar
The 91-92 GM fenders have an extra hole cut into the bottom because the ground effects bolted up different. If you get 90 fenders all you have to do is cut a 2-3 inch slit so the ground effects will fit.
Old Oct 7, 2002 | 07:44 PM
Tobe2wild's Avatar
Thanks. Thats all i needed to know. Derek
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
whitehooptie
Aug 10, 2015 07:02 AM
Boss002
Jul 24, 2015 10:47 AM
240ssLs3
Jul 13, 2015 05:06 PM
ducttape1975
Jul 10, 2015 06:29 PM
