LT1 TB on a TPI???
Old Sep 25, 2002 | 12:37 PM
i RoC U's Avatar
LT1 TB on a TPI???
hey guys,
i was wondering if there was any way to convert the lt1 TB's to work with a tpi system? im asking mainly cause i can get a great deal on a 58mm TB from an LT1, but i know it wont work with my 383 TPI. is there anything i can do/change to get this piece to function on my car???
thanks
Damien
Old Sep 25, 2002 | 10:41 PM
rickyzZ28's Avatar
I think, but dont quote me that if the TB is from a 93 car it will work, but if it is from another year it will not have a link for a kickdown cable on it.
Old Sep 26, 2002 | 02:19 PM
CASPER97TA's Avatar
Actually summit sent me a LT1 TB when i had my 89 iroc 350. The water jacket that bolts up to the bottom is routed differently on each one and it blows water everywhere when u start the car.
Old Sep 26, 2002 | 05:47 PM
i RoC U's Avatar
hmm, well that blows. thanks for the help guys.
Old Sep 26, 2002 | 08:05 PM
amish_Z28's Avatar
Talking YES YOU CAN!
Actually you can modify the lt1 intake to fit into a thirdgen. Go to http://www.lt1intake.com/services.htm, they can show you how or you can buy one from them. I am doing this or a TPIS mini-ram.
Good Luck
Old Sep 26, 2002 | 09:38 PM
LJ93Z28GM's Avatar
If you want to bypass the waterjacket at the bottom of the TB on a for a LT1 just do not connect the lines.
Take the lines and connect them together so they bypass the TB, most LT1 guys do it anways so it does not heat the charge of air passing through the TB.
Old Sep 28, 2002 | 03:10 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
He's not talking about an LT1 intake manifold, he's talking about an LT1 throttle body. It will physically bolt up, but the throttle cable is different, and as said above, only the 93 will have the provision for the 700R4 transmission cable.
Do a search on this forum, this topic has been discussed several times.
Old Sep 29, 2002 | 04:37 PM
Markolc's Avatar
'89-up throttle cables will work with LT1 TBs. I'm doing it right now, and so are my friends. If you have a pre-89 car, just buy the throttle cable from GM, they're about $15.
Old Sep 29, 2002 | 05:12 PM
i RoC U's Avatar
my car is an 89 IROC. so ur saying i CAN hook up an LT1 TB then?
*crosses fingers*
STR FTR 1
Feb 10, 2015 10:36 PM
4586
Dec 31, 2014 02:21 PM
4586
Dec 6, 2014 05:20 PM
Jul 4, 2005 05:00 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
