timing for 92 305 TPI
Old Sep 30, 2002 | 04:00 PM
AXMAN's Avatar
Question timing for 92 305 TPI
I was wondering what the timing should be set at for a 1992 Camaro Z28 305 TPI. I think it was set for performance when i first got it but i recently had it tuned and i think they set it back to stock, idiots. I've heard 8 - 10, what do you think?
Old Sep 30, 2002 | 04:07 PM
91RS5speed's Avatar
I run mine at 10 if thats to much for yours bring it down till it runs right.
Old Sep 30, 2002 | 04:34 PM
AutoRoc's Avatar
I'm running 8 with pretty good results in the hot summer air. Engine temp is usually around 160-180.
Tried 13 Pinged... 11 and it pinged pretty bad too
I'm even hitting it with a 100 shot on 8 degrees so far. No testing but i'm sure a little retard will help power. Who knows
Old Sep 30, 2002 | 08:29 PM
aklim's Avatar
Thumbs down
When a person does this, it raises the timing throughout the entire band. The ECM thinks it has so many degrees of timing based on the fact that it assumes that you have set it to 6 deg. If you set it to 8 deg, it still thinks you have 6. The proper way to get more timing is to go into the chip and do it there. For certain RPMs, it might flow better and certain it does not. As such, it might feel better but have some light knock at WOT. The ECM will retard the timing but it needs to knock before the ECM will retard it. The KS is a safeguard not to allow you to run as much timing and disregard it. Each time it pings and retards the timing (loses power) it hurts the engine. Either learn to write your own EPROMS or get someone to do it for you.
Old Sep 30, 2002 | 09:14 PM
90rocz's Avatar
Check your VECCI label under the hood, it tells the engine size (5.0L/5.7L etc),plug type and gap, the timing (6*BTDC) it even tells you to disconnect the EST wire etc,etc....
For performance, yes, start at 10*BTDC raise it 2* at a time until it pings, then back it off 2*. If you use a chip as JET/Hypertech etc, use the stock setting like 6*BTDC , b/c they add timing in the chip.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
STR FTR 1
Feb 10, 2015 10:36 PM
capebuf
Jan 13, 2015 07:22 PM
hotrod 5210
Dec 22, 2014 07:28 AM
Carguy00
Aug 6, 2002 10:25 PM
