forged vs hypereutectic pistons
Old Sep 26, 2002 | 04:41 AM
99huggerorangeZ's Avatar
Question forged vs hypereutectic pistons
i am building a 383 stroker and when completed will have 500hp and 500 ft lbs of torque but i need to know the pros and cons of forged and hypereutectic pistons and whcih would be better for this engine?
Old Sep 26, 2002 | 08:05 AM
kmook's Avatar
Advanced Tech Moderator
Please post general tech questions in the proper forum...
Since you have a 91, i will move this to 3rd Gen Tech.
Thank You.
Old Sep 26, 2002 | 11:23 AM
aklim's Avatar
AFAIK, Forged is stronger but expands a little more than hyperutetic pistons. As such, there is a little more clearance required and may rattle when cold. So it went. I never had that problem and mine were forged. Not sure of the truth of the matter but that is what I heard. It is also more expensive.
I do know they are stronger so if you are building that much power. I would not cheap out and get the hyperutetic pistons.
Old Sep 26, 2002 | 01:10 PM
angel71rs's Avatar
I broke 2 Keith Black hypereutectics in my 400 sbc, so I recommend paying the extra for forged.
Forged come in different alloys. Replacement types (TRW's), expand less, so are run tighter and less likely to rattle. The super dooper $$$ pistons tend to use alloys that expand more, so need more clearance.
Old Sep 26, 2002 | 04:36 PM
91RS5speed's Avatar
Hypereutectic is an alumium alloy. These will be lighter than forged but not as strong. If you looking to super charge or spray go with forged.
Old Sep 26, 2002 | 07:45 PM
Aaron91RS's Avatar
hypereutectic=CRAP, i'll take the stock pistons over them
TRW forged = CHEAP as hypereucrap and way stronger
Thats what I use
Old Sep 26, 2002 | 11:25 PM
aklim's Avatar
AFAIK, the stock ones are hypereutectic.
Old Sep 27, 2002 | 02:31 AM
oil pan 4's Avatar
hypereutectic don't expand as much because ther made with up to 12% silicon. silicon is high tensiel strength and won't expand under engine temp. conditions.
I don't belive in the shearing strength of the metal ther made with. They are normaly don't bend or streach they just break or shatter.
There also cast like a normal piston.
As far as forged aluminium there $$$ but worth it.
The Al alloy ones most of the time have magnesium which loves to expand when warmed.
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
