radiator cap?does it affect runnin temp????
Old Sep 24, 2002 | 07:26 PM
ratdog's Avatar
Question radiator cap?does it affect runnin temp????
i read somebodys post and they said,they changed their cap,and the car ran cooler ,is this possible?if so please xplain. thanks T.T
Old Sep 24, 2002 | 07:50 PM
Sitting Bull's Avatar
Well, if the cap is not a tight fit or doesn't actually seal the rad to the 15 lb. per square inch advertised limit (that is just a number off the top of my head) then the system will have a lower boiling point and can't cool to its design parameters.
Old Sep 24, 2002 | 08:39 PM
TheGreatJ's Avatar
Well mines 16psi but Bull is right a bad cap can cause cooling problems by venting off coolant that needs to stay in the system. Less coolant=less heat removed=hotter engine.
Old Sep 24, 2002 | 09:00 PM
Actually, it is the increased boiling point of water under pressure that lets it cool better without boiling over. The boiling point will go from 100*C to say 120*C if the system is kept at 16 pounds per square inch by a cap that won't vent until it hits 17 pounds.
Numbers aren't exact but you get the idea.
Old Sep 25, 2002 | 01:31 PM
TheGreatJ's Avatar
Actually Bull I got the idea when I took my Heat Transfer and Fluid Flow classes......but not everyone has been through that so I try to keep my explanations simple.
Old Sep 25, 2002 | 01:37 PM
OK
calaban
May 18, 2020 06:43 PM
asilomar244
Jul 12, 2015 05:53 AM
SergheiS
Jul 5, 2015 03:27 AM
Biggiebound
Apr 23, 2015 08:50 AM
Jul 4, 2005 05:00 PM
