where to find out which gears in 9bolt
Old Sep 28, 2002 | 09:45 PM
phoenix916's Avatar
I'm working on a 86 Trans Am SE and would like to find out what gears it has. I know it is supposed to be on a tag somewhere. Where should I look and what numbers mean which gears? Thanks in Advance.
Brett
Old Sep 29, 2002 | 07:58 AM
87DJP2001's Avatar
Pull the cover and check the ratio stamped on the ring gear. The rear probably needs a fluid change anyways and you will be positive what ratio it is and not some speculation.
Old Sep 29, 2002 | 03:27 PM
Damon's Avatar
Block front wheels, put tranny in neutral, release e-brake, jack up ONLY one rear wheel off the ground. Make a mark on the wheel and one on the driveshaft (it'll be clear why shortly).
Rotate the wheel EXACTLY 10 revolutions WHILE COUNTING driveshaft revolutions (and fractions of revolutions).
Take driveshaft revolutions observed and multiply by 2. Divide the result by 10 and that's your rear end ratio. It won't come out perfect becuase of observation errors and the slight slop in the drivetrain but it will be plenty good to figure out if you've go 2.73s, 3.08s, 3.23s, whatever.
Old Sep 30, 2002 | 08:57 AM
88 427 Camaro's Avatar
The only way to know for sure is check the ring gear. 2.77, 3.27 and 3.45 were the common factory ratios. Ratios to 4.10 are now available for the 9 bolt.
More information is available at www.9bolt.com
Miles
Diff Solutions
HectorM52
Jul 30, 2017 11:46 AM
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
Nostang 96z
Sep 10, 2002 08:54 PM
Nostang 96z
Aug 31, 2002 12:01 PM
