What is the Lobe Seperation on an '89 L98 Cam???
Old Sep 25, 2002 | 02:50 PM
1fastformula's Avatar
Question What is the Lobe Seperation on an '89 L98 Cam???
Just what the topic says
Later
Old Sep 25, 2002 | 08:16 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
The information I have from the cam tech article over at http://www.thirdgen.org/ says that cam has an LSA of 117.
Old Sep 25, 2002 | 09:02 PM
Thumbs up
Just seeing how much chip work I am in for....The Crate cam has an LS of 112 or 112.5.......Stock chip definitely will not work...Hypertech thermomaster will have to do for break in period!!!!!
Later
Old Sep 25, 2002 | 11:16 PM
RedIrocZ-28's Avatar
My cam is a 110* LSA and ran on the stock chip. Might I suggest trying the ARAP.bin? That one would better suit your needs especially for breakin. 112* LSA cam would be a dream to tune compared to the 110*. You have it made FYI the Speed Density cars had a 114* LSA... Some earlier 3rd gens had 108*LSA stock. As long as you use the ARAP.bin I know you will be OK.
Remember to turn the fan's on in the ARAP.bin. They are set much too high and the 2nd fan doesn't come on until around 220* I believe. ( I haven't looked in a while) Turn it down to about 180* or so.
Good Luck!
Old Sep 25, 2002 | 11:27 PM
Kevin91Z's Avatar
Later
I hate to break it to you, but your super-duper Hypertech chip is nothing more than a stock chip with some more timing at wide open throttle, and the fans turned on sooner.
And I think your stock chip will work just fine with a 350 HO engine.
Old Sep 26, 2002 | 09:13 AM
Zepher's Avatar
If I remember correctly, the ECM only controls the primary fan. The secondary fan is controlled by a temp sensor in the pass side head as well as the high pressure switch on the the A/C System.
If I am wrong, please correct me.
Old Sep 26, 2002 | 11:10 AM
Thumbs up
Well....I have to wait till shop opens ( I live in Louisiana...ISIDORE) until I can get the 4 digit number off the chip. I called fastchip and I guess that is who I am going with....They are supposed to be the best in the market and everyone has the same chip price. I know my Hyperjunk chip is garbage, but I just thought it would be better than the stock chip.....Looks like I am going to yank out stock chip, get fastchip next day air, and install back in without worrying about it all.
Thanks for all your help on this topic and I will post you soon on the outcome...
One more thing...Does 1500 miles sound like a good break in period before I put the get down on it???
Later
All the members on this board
rideordie
Nov 5, 2019 04:52 PM
Queens94z28
Nov 20, 2014 06:03 PM
