engine idles high
Old Oct 12, 2002 | 09:18 PM
black splitter's Avatar
engine idles high
When I start my car and let it sit for a few minutes it idles ok. But the when it sits for more than a few minutes it's starts to idle high and then clicks and goes back to normal. why does it do this?
I have a 1985 Z28 with a 305 carb. engine, with only 114,000.
Old Oct 13, 2002 | 12:32 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
You might have a broken vacuum line, or something is plugging the carb.
Old Oct 13, 2002 | 07:30 AM
funina91ss's Avatar
See if the click is not the A/C compressor kicking on wich would cause the idle to go up it will do the same thing on defrost. If that is what it is doing how much is it going up?
Old Oct 14, 2002 | 08:36 AM
tigersZ's Avatar
I have a 1984 Z-28 and I have the same problem. When I start it the idle will go up between 20-25 sometimes as high as 30. Once it warms up to about 110 degrees it drops. I am not sure if that is the same problem you are having. I just let mine warm up and give it a little gas and then it is fine. Hope this helps.
Old Oct 14, 2002 | 11:17 AM
TheGreatJ's Avatar
Tiger the only thing that's wrong with yours is the choke "fast idle" is set too high. Should be right around 2k. Theres an adjustment screw on the side of the carb for it but on a Q-jet I'm not sure where it is.
Splitter....the whole thing is kind of confusing...I wanna say it's an IAC problem, but I don't even know if the Q-jet cars HAD an IAC (or similar mechanism). Take a close look at the carb one day and wait for it to do it....see if anything is pushing the carb linkage over and then releasing it. Thats all I can come up with.
PCLZ28
Dec 24, 2015 05:19 PM
edman
Jan 25, 2015 02:41 PM
David Dorris
Jan 17, 2015 08:10 PM
IRABuss
Sep 7, 2011 09:08 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
