LT1 Stroker TT into 85 T/A
Old Sep 23, 2002 | 11:20 AM
blown4now's Avatar
Well, my original plan was to do a 4.1L Stage II GN motor for the car, but just too much hasle/cost, so I've decided to go with a TT LT1 383 stroker. Has anyone tried the swap, just the LT1 into a third gen? How difficult is it? And what is required? I can get the LT1 front Suspension, will it swap and will the be easiest?
Jake
Old Sep 23, 2002 | 02:32 PM
LT1Powered85Z's Avatar
Yep...I've done it...twice.
Check the link in the sig...
Eric
Old Sep 23, 2002 | 05:44 PM
blown4now's Avatar
Good deal! You will probably be getting a few emails every now and then with some ? when I start the swap. I'm planning on doing the a/c delete, so I can use the third gen k-member and mounts right?
Jake
Old Sep 24, 2002 | 12:33 PM
Yep...should go in just fine.
I need to update that write-up I did...but for the most part everything's still accurate.
I'm used to getting questions. I would venture to say that I've answered quite a few hundred e-mails asking LT1 swap questions, over the last 3 years.
Eric
Old Sep 24, 2002 | 08:07 PM
irocbob89's Avatar
the lt1 swap was easier then i thought it would be. It was worth all the time and money to do it too. It would be nice to be able to afford the 383 tt part but im very happy with my stock lt1. I put it in my iroc that is really close to mint condition and i love it so much more now that it has an lt1. Good luck and if you have any questions the post, there are about 5 of use that have done the swap and can help you out. later
Bobby
Old Sep 24, 2002 | 09:12 PM
blown4now's Avatar
Thanks guys, I've found most of what I need...now just time to gather parts (which means money). Have you priced a set of Arao heads lately!! How bout a Hogan intake??!! Wow, good thing I'm looking at a sponsorship!
Jake
Old Sep 25, 2002 | 05:51 PM
Kory 88 Iroc Lt-1's Avatar
only 5 I know there are alot more than that running around
The swap was well worth it. My only gripe is the stupid opti
Kory
Old Sep 25, 2002 | 10:39 PM
rickyzZ28's Avatar
I have done the swap although school is really messing up me driving it. Just take your time and do it right it is definately worth it.
Old Feb 11, 2009 | 03:32 PM
camaro383tt's Avatar
Member
how did the swap turn out?
Old Feb 11, 2009 | 03:42 PM
irocbob89's Avatar
6 and half year old thread...hope hes still around..HAHA.
Old Feb 11, 2009 | 07:37 PM
AutoRoc's Avatar
last activity was November 2003...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
