hatch wont lock
Old Sep 23, 2002 | 08:04 PM
John Halas's Avatar
Unhappy hatch wont lock
help i opened rear hatch and now it wont lock the motor that pulls it down does not make any noise at all when the kid is shut and it wont lock have checked the fuse at the fuse panel and it is good any helpor suggestions on how to fix
Old Sep 23, 2002 | 08:49 PM
camaro6's Avatar
It sounds like the rear hatch motor isn't working. You'll probably have to go get a new one. I believe there kind of expensive. You might just want to go to a junk yard or somewhere and find a motor for it.
Old Sep 24, 2002 | 03:58 PM
1989gta's Avatar
Is the motor in the down position?
If so then when looking down there should be switch you can push with a screw driver or your finger to make the motor come back up then set the hatch on it, it will lock and pull down. Happens to mine all the time if you trigger the motor and dont catch the hatch.
Old Sep 24, 2002 | 08:52 PM
Rage's Avatar
Check ebay for a motor bro, $40-$50 bux. Good luck.
Aaront810
Aug 29, 2020 09:34 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
z28cam1993
Sep 9, 2015 04:08 AM
92_RS_305
Sep 8, 2015 07:47 PM
