383 stroker
Old Oct 1, 2002 | 06:18 PM
stevem's Avatar
Question 383 stroker
will i need a new flywheel when i get my motor back.
what else do i have to change.
Old Oct 2, 2002 | 01:11 PM
Damon's Avatar
If it's an externally balanced 383 (most are) then you are correct, you will need a 400-style flywheel with the appropriate counterweighting. You will also need a 400-style 8" harmonic counterweighted dampener on the front of the engine. Also, stock 3rd gen 305s and 350s use a straight bolt pattern starter, designed for a 153 tooth flywheel. 400-style flywheels are only available in 168 tooth style, so your stock starter won't work. I highly recommend an aftermarket mini starter- much higher torque to flip over a big-cube high compression motor, especially when the motor is hot. THey alo clear msot sets of headers much easier.
That's the big stuff. THere will be a bunch of other small stuff that I missed, I'm sure, so don't try to do the install like you're meeting a deadline. There WILL be minor delays.
Old Oct 2, 2002 | 04:53 PM
HiTech5's Avatar
If you have a 700R4 trans, you will need a 153 tooth flexplate. Is the motor externally balanced? If so, Lingenfelter Performance Eng. carries the flexplate you need.
Old Oct 5, 2002 | 05:38 PM
Damon's Avatar
Actually, a 168 will clear the 700R4 bellhousing just fine. Did it last summer with a 400 in an 87 GTA with 700R4 trans.
Old Oct 5, 2002 | 07:06 PM
irocbob89's Avatar
My 386 is internally balance, i made the mistake of using my stock 350 fly wheel with my stroker. It took me alittle while to figure out the vibration. My stoke flywheel had a balancing wait on it. I ordered a b&m flywheel for a 700r4 from summit. Im pritty sure it was the same size as the stoke one. Just make sure you know if its internially or externally balanced.
Old Oct 5, 2002 | 07:30 PM
TunedPort 341's Avatar
Wrong. My starter works fine, it doesnt need a 168 tooth flywheel. My stroker kit came with the stock size 153 tooth. My car is basically the same thing as a 383 except it has smaller pistons for a .030 over 305. It starts fine when the motor is hot also (I got 10:5 CR)
You are right though about needing an 8" balancer, he will also need a new timing chain cover because the stock timing tab won't clear the new 8" balancer.
Good luck with your 383
Quickss96
Jan 29, 2016 05:56 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
alphaauto
Jul 26, 2015 04:40 PM
