air pump question
Old Oct 30, 2002 | 02:36 PM
1st GTA's Avatar
air pump question
If the air pump fails on an 87 GTA (305 MPFI) would that cause it to idle rough, back fire and die when you give it gas?
Old Oct 30, 2002 | 05:24 PM
bluirocz85's Avatar
It can because the oxygen sensor is basically reading wrong. The air pump pumps air into the exhaust before the O2 sensor reads it, therefore if the air pump is not working, the computer is being fed the wrong info.
Old Oct 30, 2002 | 06:30 PM
oil pan 4's Avatar
I took the air pump off my MPFI 2.8 and It didn't change any thing.
It might be some thing else.
Old Oct 31, 2002 | 10:36 AM
1989gta's Avatar
the only thing the air pump does is pump exhaust back into the motor. If it's not pumping exhaust into the engine the o2 sensor see's this an makes the changes. I too do not have the air pump connected.
Isn't your air pump pulley driven?
Old Oct 31, 2002 | 08:44 PM
Stephen 87 IROC's Avatar
EGR pumps exhaust back into the engine.
The AIR pump is a polution control device used to lower emission levels. When an engine is cold and running rich until it warms up, the emissions are very high. The AIR pump pumps air into the exhaust to mix with the unburnt fuel and lowers the emissions. Once an engine is up to operating temperature the AIR pump is just along for the ride and serves no other purpose.
Old Oct 31, 2002 | 09:07 PM
irocbob89's Avatar
If its back fireing and dieing sometimes then it might be a vacum leak or an intake gasket that needs to be changed. I remember i forgot to put the gasket on between the tb and plenum of my 5.7 tpi car and it did exactly what your car is doing. It might also be the egr. I highly dought its the airpump. But if it is then just take it off.
HectorM52
Jul 30, 2017 11:46 AM
linz
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
