HEI in my 87?
Old Oct 18, 2002 | 08:26 PM
BamaZ28's Avatar
Question HEI in my 87?
Whats the deal with the separate distributor and coil on my 87 LG4 T/A?
BamaZ28
Old Oct 18, 2002 | 09:58 PM
87ROC's Avatar
That sounds like your computer controlled distributor and its coil which is hooked up to your ecm that also controls your carburetor based off of readings from various sensors and what not.
You can convert to HEI vacuum advance type if you want. An older style Q-jet or new aftermarket carb would be neccessary for that also.
Old Oct 19, 2002 | 12:50 AM
brodyscamaro's Avatar
yep its not HEI
Old Oct 19, 2002 | 11:04 AM
Marc 85Z28's Avatar
Originally posted by brodyscamaro
yep its not HEI
Ummmm... Yes it is HEI. They came in 2 styles: coil in cap and remote mount coil.
The remote mounts were designed for better clearance in tight engine bays.
Old Oct 19, 2002 | 06:46 PM
87ROC's Avatar
Call it what you want to, if it ain't got vaccum advance and it has more than a bat and tach line plugging into it, then it is probably a computer controlled set up. That is not the one I think BAMAZ28 is used to dealing with in his older second gen car.
Old Oct 19, 2002 | 07:27 PM
90rocz's Avatar
Yes, it's an electronically advanced HEI with remote mounted coil, and yes controlled by the computer. Set timing according to the procedure and #* on the VECCI label under the hood. It's the one that also has the type and gap for the plugs and vacuum line diagram.
I think he was just suprised by the remote coil set-up...
Old Oct 19, 2002 | 09:48 PM
BamaZ28's Avatar
Yes I was surprised when I saw the remote coil. Hmmm.... is this a good thing or a bad thing? I was expecting the...usual...HEI, like on my 81 SBC. I guess it has it's advantages. Once again, thanks
BamaZ28
Old Oct 20, 2002 | 05:41 PM
Marc 85Z28's Avatar
Good...bad... ? The only downside to having the remote mount coil is having the terminals closer together - better chance for crossfire/misfire.
Chris9450
Nov 16, 2003 07:23 PM
SLO SS K2
Classic Engine Tech
13
Jun 2, 2003 02:02 PM
Langadorf
May 5, 2003 03:21 AM
TopfuelTBI
Advanced Tech
Dec 27, 2002 01:10 PM
