Hatch Squeek, how to fix
Old Oct 16, 2002 | 08:52 PM
IgorT.455/406's Avatar
Hey guys. My hatch has seen better days. Lately, it has been squeeking like crazy. I have not driven this car in a long time, but I am kinda forced to now, my 4th gen is parked. However, I don't remember the hatch squeeking that much. What can I do to prevent/reduce this? Thanks.
Old Oct 17, 2002 | 04:46 PM
fbird95's Avatar
If it sqeaks when you lift it, you need to grease the hydralic lifter strut bars. If it bounces around and sqeaks while drive and on bumps, there are these two rubber bolts on the underside of the deck lid. Turn these counter clockwise to raise the closing height of the deck lid. Be carefull though if you raise them too high they can confuse or damage a third gens pull down motor.
Old Oct 17, 2002 | 06:25 PM
Hatch is now manual, I put dielectric gel on them, no change
Old Oct 17, 2002 | 11:23 PM
IrocSS85's Avatar
try some dry lube spray on the rear window seal all the way around the hatch. that where mine sqeaks sometimes. good luck. chris
Old Oct 18, 2002 | 01:08 AM
Blownyellow's Avatar
I think my problem may have been unique in that it was probably caused by my body man, but I had squeaking and leaking issues in my hatch and it was the mounting bolts and nuts that came loose were the actuall glass is attached to the hinges. Like I said I think it was from when my hatch was off at one time during painting but I am not sure, take a look at it and it only takes a couple seconds to tighten if that is the problem.
Old Oct 19, 2002 | 04:47 PM
91RS_Rider's Avatar
my hatch is uneven with the back, its like not raised high enough any ideas on how to fix that?
Old Oct 19, 2002 | 05:15 PM
Go to www.thirdgen.org and look in the tech articles section. There is an extremely in dept discription on how to fix the hatch alignment problem.
magman
Apr 15, 2016 03:08 AM
WobblySausage
Oct 7, 2015 02:44 PM
Fatdog2
Sep 16, 2015 11:04 PM
Aaront810
Sep 11, 2015 11:24 AM
92_RS_305
Sep 8, 2015 07:47 PM
