Help!!! Suspension Q's
Old Oct 19, 2002 | 05:55 PM
1SLOSBC's Avatar
IVE GOT A SPOHN TORQUE ARM, LCAS, PANHARD BAR AND A SET OF SFC'S
this is all on a 88 iroc with factory swaybars,springs, and shocks as of now.
what springs and shocks are you guys using for maximun et on the 60ft....and still be street drivable??
please help
tj
Old Oct 19, 2002 | 07:40 PM
90rocz's Avatar
If you want to plant the tires harder, you need to change the IC(Instant Center). This is effectively done by lowering the "rear"attaching point of the LCA's. There are a number of companies offering brackets to do this, but I don't have a catalog in front of me. But they lower them by about 3-inches.
The IC is the point where imaginary lines extended forward from the LCA's centerlines, crosses the centerline of the torque arm. As you lower the rear of the LCA's you make these lines cross farther rearward, which pushes harder up on the car and down on the tires instead of pushing in a more forward direction. Which will PLANT the tires!
Old Oct 20, 2002 | 04:16 AM
1SLOSBC's Avatar
re
well have i have those, but i am looking to get more weight transfer.....car not getting the 60ft that i would like.... a few of my friends have similar engine combos.....
they use all v6 stuff from the junkyard...
i was looking into doing it right with shocks and springs.
what are you using?
tj
Old Oct 20, 2002 | 04:56 AM
Blownyellow's Avatar
Well if you are looking for street and strip performance you have to make a compramise either way. In my set up I chose Eibach sport lines with Koni red adjustables. I guarantee that you will not have the best weight transfer, however when I set the struts at four for softness it gets some pretty good lift. I was running a 1.60 with a global west torque arm system, mac boxed control arms, global west pan hard, eight point bar, and a 3.73 through a six speed, on 10.5 ET streets. My car is totally a street car besides four or five passes a year on the track. With my new combination this year comming up I should pull 1.30 and still be able to pull rubber on my 255/50/16 street tires at 70 miles an hour. Just immagine what times you should run. then build your car accordingly.
Old Oct 20, 2002 | 10:21 AM
1SLOSBC's Avatar
koni
how do you like the koni's on there? do you have them on front and rear?
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
97blackformula
Aug 27, 2015 06:02 PM
force10
Jul 30, 2015 04:56 PM
mrwz28
Jul 8, 2015 09:11 PM
