Oil pressure
Old Oct 18, 2002 | 12:08 PM
Bristol's Avatar
Oil pressure
Just out of curiousity, what is the oil pressure reading supposed to be at idle on a 1991 Z28 with a 350cid?
Old Oct 18, 2002 | 08:21 PM
Red89GTA's Avatar
Well, I have an 89 GTA with the 350 TPI motor and (when warmed up) the oil pressure sits at about 18 to 20 psi I believe. Obviously, when cold it is higher (about 38-40) and drops as the oil warms up. Basically you'll be ok as long as it is over 12 or 15 when warm.
BTW, this is just observation, if anyone thinks I don't know what I am talking about feel free to say so.
Old Oct 18, 2002 | 08:54 PM
TheGreatJ's Avatar
They say an engine needs about 10psi per 1000rpm.....but I wouldn't trust anything that idled at less than 15psi warm. Mine keeps about 20psi on the not-so-accurate stock gauge.
Old Oct 18, 2002 | 09:10 PM
rudy's Avatar
After installing a autometer mechanical gauge on my 91 formula 350, I found the factory gauge to be somewhat optimistic in its reading, and at idle I actually had about 20lbs when hot, as compared to the factory gauge reading about 30lbs. Thats with 10w40 mineral oil.
Old Oct 19, 2002 | 12:21 AM
aklim's Avatar
Currently my ambient temp is around 60 and my pressure according to the gauge is about 30 psi
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
