IROC-Z what should I upgrade to?
Im planing to buy a nice IROC-Z for ~$2900 and its stock(215hp/295lb-torque) and I was thinking of:
-Borla Catback Exhaust $499.99
-Edelbrock Performance Air Cleaner 14x3in $58.00
-Holley 670cfm 4-Barrel Street Avenger Carb $360.00
-Holly SysteMax Engine System $1350.00
Im hoping atleast ~350rwhp/420rwtq is this estimation too high? And are thease good choices, thanx
SSXeon
SSXeon
Sounds like you bought a 305, but the numbers are high for a carb version. I do not know what youi are trying to fo with those Mods, but you Can Not Add the numbers toghter to get RWHP. It Does not work that way. Again what engine do you have???
Re: IROC-Z what should I upgrade to?
SSXeon
SSXeon
Edelbrock Air Cleaner-
Holley Carb- If you look closer you will realize that Holley offers a SysteMax package that includes heads, cam, intake, carb, and aircleaner. I think it costs around $2800 for everything. I would recommend this system if you want a good streetable combo.
Originally posted by IROC5.7TPI
Borla- Forget about it. No increase in power over comparable systems and no justification to blow $500.
SSXeon
I guess it would be just better to get a LT1 put in by christmas, I really wanted close to 500rwhp/rwtq out of this 5.0L but if its not possible ill just order a LT1/T56 and get the 350HP/400lb-tq with a 350/ramjet combo.
SSXeon
SSXeon
Re: Re: IROC-Z what should I upgrade to?
Really? How is it that there is no increase in HP, but with a borla catback for a LT1 gets ~20-25hp? And Ill looking into that combo, looks very nice
SSXeon
SSXeon
So it's a 5.0? Is it an LB9, Lg4. Lo3, or L69? Either way, to reach your Hp goals you're gonna need an engine swap. And i personally don't think an Lt1 would be very cost effective for that kinda HP. Sure an LT1 can make that kinda power, but it will cost a lot of dough.
I would look into a custom built 383 or a high HP crate engine. Convert to carb (if not already) and put some juice to it.
Good luck.
Good luck.
Good luck.
Good luck.
SSXeon
A t56 swap is much more complicated than simply tossing in a T56 and bellhousing. You need the flywheel, clutch, master/slave cylinder assembly, shifter, speedo cable adapter, crossmember and other miscellaneous things. The trans swap alone would cost near the price of the car....or more.
I bought a GM Goodwrench crate from I think it was Pohanka chevy for about $75.99 and put it my camarobird and I am getting
450 RWHP & 650 RWTQ. All of this with my Ramjet TBI.
Im going to do this around jan of next year after my $1000-1200 month paychecks saved up, and a $1500 cash for christmas will help alot. Im pretty sure I can get the IROC-Z28 I mentioned above for $2500-2700 being that the car will need a new paintjob, headlight, driver seat, radio, and some soft spots need to be sanded and repainted. Why is everyone making fun of me and sh*t, you guys need to act a bit more mature
SSXeon
