Vats
Old Oct 23, 2002 | 01:43 PM
irocbob89's Avatar
Vats
I took my stearing column apart Yesterday to fix some of the motion it had, well i fixed it but i also cut 2 wires that goes to the Key. I think they where white or orange. I forget, however the VATS is ceeping me from starting my car, does anyone know how i can by pass it or just get rid of it? Thanks for the help
Bobby
Old Oct 23, 2002 | 03:58 PM
LT1Powered85Z's Avatar
Check my post in your other thread...but...
Call TPIS at 952.448.6021 and ask for Jim. Tell him I told you to call...he's very good...and can help you out and get it all set to go.
Eric
Old Oct 23, 2002 | 04:01 PM
1fastformula's Avatar
Thumbs up
Two options......One: Check the resistance of the key(diode in the key) and buy you a resistor that matches...sodler it onto the wires and DONE!!!!....Second....Buy a new lock cylinder without VATS (25.00) and replace the old one. Take old one wtih key inserted and slip it under dash (with wires hooked up)...the ECM will see the diode and let you start your car with the new cylinder. Also acts like an anti theft....Pull old key out and no one can start the car!!! I just went ahead and replace mine with a new Vats for about 80.00 from GM dealership
Later
Old Oct 23, 2002 | 04:43 PM
Later
That is SO redneck. But to each their own.
Eric
Jeff1904
Jun 5, 2016 05:00 PM
walt355
Mar 16, 2016 09:35 AM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
