1987 iroc fusebox, HELP!
Old Oct 16, 2002 | 02:10 PM
StealthElephant's Avatar
i left my window cracked, it rained overnight, water got in the paneling, my lock/unlock is going crazy....what fuse will shut them off? some are labeled easy like "wipers" etc but none say door locks or anything....anyone give me a hand? red? yellow?
Old Oct 16, 2002 | 02:33 PM
tigersZ's Avatar
I have a 1984 Z so I am sure that the fuse boxes are the same. Pull the fuse that controlls the radio and interior lights. I blew that fuse and the door locks didn't work so try that one. If you have the manual check in there they list what every fuse controls. I hope I helped. I think the fuse is a 25 amp fuse. so pull that one and see if that works. I think it is labeled as courtsey lights or something like that.
Old Oct 16, 2002 | 03:15 PM
1fastformula's Avatar
Thumbs up
It is the one he said above.....Try this.....Pull your panel down and locate the relay that controls your locks(should have blue and green wires in it). Tap on it with your hand and then try and see if it does it.....Mine did the same thing and this did the trick...If it does not work, then buy a new relay.
Later
Old Oct 16, 2002 | 04:42 PM
yea....thanks i found it.....now i just gotta wait for the door panel to dry (and put a little more effort to either check the weather channel or always keep my windows up)
Matt Dreessen
Sep 9, 2015 09:58 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
Pestilence
Aug 18, 2015 06:19 PM
