tps voltage?
Old Oct 21, 2002 | 10:40 PM
Zeueses 97 RamAir's Avatar
Angry tps voltage?
Hello my freind has 92 camaro auto. Now the question is
How many volts at wide open throttle should the tps be reading... Its a v6, it idles rough, we think its the brake booster anybody. We need the voltage readings thanks....
Old Oct 22, 2002 | 12:34 AM
RedIrocZ-28's Avatar
At WOT the readings should be somewhere over 4.00 volts. At idle they should be .54 volts I think.
The most important thing though with the TPS voltage is to make sure that there are no flat spots as you open the throttle. gl slowly....
On the other hand if the idle is rough the problem is either your IAC motor or the oxygen sensor.
truecontr3
Oct 11, 2015 09:30 AM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
Aug 7, 2015 01:26 PM
