Porting intake base, plenum, heads
No, a dremel won't work well.
You need an electric die grinder with a 1/4" collet.
Go to the link at the bottom of my sig. It has lots of info and pics showing just what to do with the heads.
Re: grinder....
Originally posted by whiteminqua
I have an air operated die grinder. Are the kits from Summit or similar worth the $40.00?
As I said, go to my thread and read it. It shows you everything you need and how to do it, (except for the plenum but that is just port matching and hogging out anyway).
What more could you want?
Go here if you need info on porting the plenum
http://www.gmtips.com/3rd-degree/dox...-port/port.htm
Its a pretty good site
oldschool
Feb 9, 2016 09:21 PM
