anyone using an electric water pump
Old Oct 13, 2002 | 09:29 PM
1SLOSBC's Avatar
help me, i am trying to get a few ideas for this setup, anyone know any tips?
tj
Old Oct 14, 2002 | 02:38 AM
Zepher's Avatar
I will be running one on my LT4. I am going with Meziere.
I talked to one of the engineers over there for about an hour one evening and he told me pretty much everything about the pumps they make.
Don't go with CSI.
Old Oct 14, 2002 | 05:26 PM
1SLOSBC's Avatar
water pump
thanks, but i am running a regular sbc not lt motor and its in a 3rd gen. i am trying to figure out how im gonna mount the alternator in there without interfering with parts on the car.
any info let me know....thanks!
tj
Old Oct 19, 2002 | 05:31 PM
lonsal's Avatar
Every manufacturer of an electric water pump list them as being for drag race cars only. Not for street use. If that is your application then you should have no problems. I would never install it on a street driven car. If you are looking to improve your engine cooling ability I recommend Stewart Components water pumps. I've had their stage II aluminum pump for a little over three years now. Be sure to get their special Robertshaw modified thermostat also.
Lon
http://www.stewartcomponents.com/
Old Oct 19, 2002 | 05:50 PM
1SLOSBC's Avatar
water pump
electric is fine on the street......but u must use a moroso unit....NOTHING ELSE WILL SUFFICE for a sbc
as for using an electric unit..they are good for a 3/4 to a full tenth and a 1/2 depending on application.....getting rid of the fan clutch is half the battle...... ive seen as much as 20hp on the dyno from using a electic pump
i found a guy local who can weld a bracket on my frame so i can mount my alternator on the low side.......
just my .02 worth
Old Oct 19, 2002 | 06:05 PM
lonsal's Avatar
What fan clutch? 1988 had a serpentine belt setup. No fan clutch. Only either a single or dual electric fans.
Old Oct 20, 2002 | 04:13 AM
1SLOSBC's Avatar
re
already knew that, just speaking in general on any setup.... not pertaining to just an 88 model
ttt
Old Oct 22, 2002 | 09:30 AM
Ucantcme57's Avatar
So no one has used a electric Water pump for street use??? What is wrong with CSI? I want an electric water pump, already have to much on the belt soon, Alternator, Supercharger,.. want to take off .. Was thinking if it doesn't seem to work any other way I could use one of those completly external water pumps that mount to the frame or soemthing..
kevin
Old Oct 22, 2002 | 11:17 AM
jerrywho's Avatar
The only electric pump for a serpentine F-body that i can find is on the bottom of the page of this link
http://www.thunderracing.com/index.c...yid=1120#T1612
Jerry
Old Oct 22, 2002 | 06:13 PM
1SLOSBC's Avatar
that sumbitch it high!!!!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Stay Puft
Apr 20, 2015 06:24 PM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
