rear brake lines for 92 camaro?
Want to know if anybody makes rear brake lines only for my 92 camaro? Or does anybody know the length or the rear lines and what connectors go on the ends? I can go to the local speed shop and have them made out of what -3 or -4 AN line.
any info would be greatly appreciated.
order the braided line out of summit from earl's........it's a hair under 100 but its absolutely worth every penny!!!
i can't even begin to explain what a difference braided lines gave my brake setup, i did however have my pads upgraded; but that was even before the lines and the lines made such a difference.
Sounds like a great idea Kandied91Z but I just recently purchased a complete BAER track system for the front and just rotors for the rear that uses the OE calipers. So I just need to find rear braided lines because the front kit comes with new lines. Does anybody know the length of the rear lines?
you know you can get them if you call.
i know a local shop around here that sells fluid setups carries all of earl's products and i've seen the rear lines. just a little more than buying the whole setup.....
could give it a try at least....just an idea.
Dec 4, 2014 11:56 AM
Jul 4, 2005 05:00 PM
