Torque converter
Old Oct 29, 2002 | 10:17 PM
Erics89Iroc's Avatar
Unhappy Torque converter
asked this question a while back and I think I stunned some people I didn't get much help.
I don't think my torque converter locks up in OD. with stock 2.73 gears my motor runs at 3k rpms. any ideas about what is going on and what I can do about it.
Old Oct 30, 2002 | 07:13 AM
87DJP2001's Avatar
What MPH are you running in OD at 3000RPM's????
Old Oct 30, 2002 | 06:13 PM
65 mph
Old Oct 30, 2002 | 08:39 PM
87DJP2001's Avatar
Eric
Well in trying to calulate RPM's & MPH and a 700R4 with 3rd gear of 1.0 and OD of .70 I keep coming up with the numbers for a 3:42
rear and NOT a 2:73. I would check your RPO codes for rear axle I.D. It is not a 2:73.
Old Oct 30, 2002 | 10:18 PM
im pretty sure that it is a 2.73 though.
i came up with that number from sinning the tire 1 time and counting how many times the driveshaft turns.
i counted it and it came up around 2 3/4 turns.
thats just what i came up with let me know if im wrong.
Old Oct 31, 2002 | 06:58 AM
87DJP2001's Avatar
Eric
The only sure way is to pull the cover and check the ring gear. That will settle the issue of your gear ratio. But I am positive it is a 3:42 and it may have been changed at one time.
Old Oct 31, 2002 | 10:29 AM
1989gta's Avatar
when driving down the road when you think the converter should be locked, try tapping the brake with your left foot. you will feel the converter unlock the relock once your foot is off the break. It's usually the solinoid that stops working or the front seal on the input shaft is leaking, (leaks internally)
Old Oct 31, 2002 | 11:07 AM
Craz-28's Avatar
I don't think that number is correct. I have 3.42 gears and at almost 2000 rpm, I'm doing around 65 mph(not positive, but I can check later). Are you sure your car is even going into 4th(od)?
Old Oct 31, 2002 | 03:34 PM
first off 1989gta I have already heard about that and have already tried it. Cant tell any difference though.
craz-28 im positive my car is going into 4th gear.
Old Nov 3, 2002 | 10:01 PM
can any one help me where is the solenoid for it at
dboone2172
May 16, 2015 07:45 PM
QuickSilver02
Apr 7, 2015 11:12 AM
F550maranello2
Apr 1, 2015 11:10 AM
StansZ28
Feb 19, 2015 07:39 AM
veryslowfbody
Aug 22, 2002 04:31 PM
