Aluminum L98 Heads
Old Oct 24, 2002 | 08:14 AM
90 IROC Conv's Avatar
Aluminum L98 Heads
I'm looking for a good set of heads for my 305 TPI, I've got a 1990 IROC Converitble and I was wondering if the Aluminum L98 Heads that came on the Corvettes would be a good purchase for the money if I can them. Or would it be better to go with a set of CNC ported heads?? I'm not sure, any other suggestions welcome.
Old Oct 24, 2002 | 11:32 AM
Perry93TransAm's Avatar
One thing to consider on the Aluminum L-98 heads is that they have no provisions for EGR.
Old Oct 24, 2002 | 12:09 PM
BamaZ28's Avatar
I was going to do the L98 head thing. Changed my mind after I found a good deal on the "camel (double hump" 2.02's. My brother has a set for $475 plus shipping, complete from a vette with about 50,000 miles.
BamaZ28
Old Oct 24, 2002 | 12:26 PM
If I did get the L98 heads, couldn't I just block off my EGR and get a chip programmed so it wouldn't throw the code??
Old Oct 24, 2002 | 12:27 PM
87ROC's Avatar
I have read and seen flow numbers showing the L98 heads flow about as bad as any production head ever made for the small block chevy. I don't think they would be worth the effort or money spent on gaskets even if you got them free. See if you can find the flow numbers on the S/R Torquers by world products. If they are more than 210 cfm at .400 in lift then you will probably be improving.
Old Oct 24, 2002 | 01:08 PM
angel71rs's Avatar
Read the sad numbers on L98 flow capabilities here:
http://www.chevyhiperformance.com/ed...=745&aid=41598
They are worse than 441 or 882 smog heads. Look at how much better the Vortecs flow. Definitely investigate aftermarket.
Old Oct 24, 2002 | 01:15 PM
Ok the L98 head is out... What suggestions does anyone have for a 305 TPI on a 1990 Converitble IROC. Of course the car is Speed Density and the entire motor is all stock, what's the best head I can get for the money??
Old Oct 24, 2002 | 09:43 PM
87ROC's Avatar
Check out this part # at www.summitracing.com WRL-042750-1. These are called replacement heads but have 170cc intake runners. That's probably 10 to 15 cc better than yours and come with screw in studs so you can put a high lift cam in if you want. It says it will fit the 305 and has the bigger 1.94 in intake valve. I personnaly have not seen the flow numbers but for 364 dollars a head complete it would be worth looking into.
Old Oct 26, 2002 | 12:59 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
There are only three heads worth considering for a 305 engine. TPI 305 heads, L98 aluminum heads, and S/R Torquer 305 heads.
Do a search on this board and you'll find all the info you want about L98 aluminum heads. I've posted it plenty of times.
Old Oct 26, 2002 | 05:11 AM
Sitting Bull's Avatar
Go to the junkyard and get a set of regular old 305 heads, just make sure they are not from a TBI car.
Then follow the instructions linked at the bottom of my sig. That will give you a set of heads that will flow like Vortecs--over 450 hp--but only cost you $400 US maximum.
*Emilia*
May 13, 2015 09:05 AM
cmyname1
Feb 19, 2015 08:38 PM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
