Please help i need a set up
i have a 99 ls1 street rod 373 detroit tru trace rear end. long tube headers and programer and 130000miles on motor i would like to pull it and re do it what should i put in to the motor i have a 1500 budget
I would change out the rod bearings, check the main bearings, and mic the crank too. Then put it back together with a new oil pump, hardened pushrods, new valve springs, and new GM replacement lifters.
You can find a used LS6 intake manifold here on the internet. Welcome.
Jan 23, 2015 01:13 PM
