po133,po153,po,704,p1134,p1154 codes need help
changed my exaust to tsp tds and these codes poped up soon after.
po133
bank 1 sensor 1 slow reponse
po153
bank 2 sensor 1 slow reponse
po704
clutch switch input malfunction (needs switch)
p1134
trans time ratio bank 1 sensor 1
p1154
trans time ratio bank 2 sensor 1
i had the clutch code before but the others are new.
what would cause these codes to come on?the car was running 65 psi of fuel pressure so i replaced the regulator but it didnt help the codes.the car feels like its bogging on take off.i dont think both of the 02s would go out at the same time, what do yall think?
__________________
po133
po153
po704
p1134
p1154
__________________
Which O2 sensors do you have? I know some people have had this problem with the Bosch sensors, but I'm running Bosch O2s with Pacesetter LT and TSP True Duals with no problems. I believe the people with problems after switch to AC/Delco (Denso) the problem went away I think.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
BigDarknFast
3rd Gen / L98 Engine Tech
Jul 8, 2002 01:37 AM
