Same problem different day !
Old May 6, 2010 | 05:28 PM
ANDYLS1's Avatar
I am having an intermittent starting problem the battery and alternator are fine.when you turn the key everything comes on and it shows plenty of juice,but it wont even crank it just turns everything on,ive noticed it happens alot when its raining all day steady or a cool damp morning.
Any ideas !!!!!
Old May 19, 2010 | 01:31 PM
GhostZ28's Avatar
https://www.camaroz28.com/forums/sho...d.php?t=750237
first, I wouldn't use the weather as a cause becasue lots of morning are cool and damp or humid, and its usually always coincidental, so you should just troubleshoot as normal
this might help. I read that the ignition signal goes through the body control module and apparently the only common failure is broken soldier joints on the tall relay or the relay going out.
but first check your starter. remove it with a ~1/2 inch socket w/ extension (only 2 bolts, the ones closest to the transmission and 2 nuts that hold pos and neg) be sure to remove your pos battery terminal first. its easier to remove the bolts then undo the nuts with it hanging by the wires. it should only take you about 10 min to remove it. Autozone/Advance will test it for free. Most rebuild shops only cost around 60-80 dollars for a starter rebuild.
If that is a no go, do what I'm headed outside to do, replace the ignition switch.. and thats a fun one, the whole steering column has to come out. (but its way easier than it looks)
ignition switch: http://shbox.com/ignsw/ign_switch_repl.html
Old May 20, 2010 | 01:36 PM
Marc 85Z28's Avatar
Any ideas !!!!!
How do you know the battery is fine? You CANNOT determine a battery's condition by the dash voltmeter.
You probably have a discharged battery. Have it tested - properly.
liamcg97
Nov 25, 2019 05:55 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
karnykamaro
Feb 2, 2015 01:37 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
nophix
Nov 30, 2014 10:26 PM
