looking for some easy mods
I have a 98 ls1 car it only has a couple of mods on it. I ran it at the track last weekend and it ran good it ran a 8.33 at 86 mph. It has a cold air intake, underdrive, programmer, and a off road y pipe no converters with a 3" cat back. What are some of the free mods that i can do to help it perform a little better. I was going to try and port the mass air this weekend. Does it help much to block the coolant from going into the throtle body? Thanx for any help or sugestions
LEAVE THE MAF ALONE. The MAF is very sensitive and screwing with it will likely cause reverse results. Again incase you didn't hear me the first time. Leave the MAF alone it's fine in it's stock form.
Ported TB..........ok
EGR bobbit or complete removal.............ok
Throttle blade bump stop mod..................ok
Weight removal.....................great mod
TB coolant bypass...............good to keep TB heat soak down.
what is the bump stop that you are talking about? I am not that familiar with the newer cars still old school i guess. I didnt do the mass air. my car has some weight reduction a tubular k member with chrome moly a frames. thanx for all of the suggestions so far
If i bought another programmer which 1 is better i dont know any place around here that programs them. And I have everything cut out on the cold air i put the slp lid and the metal peice in front of the rad. the guy that i bought the car from had removed the part between the filter and the support. Thanx again for your help
CARiD
Sep 30, 2015 05:44 AM
NewsBot
Sep 15, 2015 11:53 AM
