throttle body 80 or 85?
Old Oct 22, 2010 | 08:45 AM
2000 maroZ's Avatar
80 or 85mm Throttle Body w/ Cable Style Linkage what do you guys think?
2000 z28 LM2 ORY air lid
Old Oct 22, 2010 | 11:51 AM
Marc 85Z28's Avatar
80mm or 85mm means you're looking at aftermarket, which you should not do.
For either an LS1 or LS6 intake, go with a ported stock throttle body. They're cheaper and don't cause drivability issues like most aftermarket. Also, a ported stocker will make the same if not better power. The stock LS1/LS6 intake doesn't have a large enough opening to properly accomodate anything larger than 78mm.
Old Oct 24, 2010 | 01:54 PM
bluz28's Avatar
I'd try going with a ported GM TB first, but you could easily run a 80mm with a very minor opening up (1mm all around) of the intake opening.
Old Oct 31, 2010 | 10:58 AM
kornboy810's Avatar
Re: throttle body 80 or 85?
Go with the 85mm.It should come with a adapter plate,so no need gind up your intake...
Old Nov 1, 2010 | 09:58 AM
Chrome383Z's Avatar
Just port your stocker until you have an intake that can utilize the larger TB. You could send your LS6 intake to TPIS and have them make it a 90mm intake. It's a decent upgrade.
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
