2000 Camaro - LS1 and Blue Smoke
Old Jul 27, 2010 | 07:48 AM
bts's Avatar
bts
Hello all, need some advice on what/where to look. 2000 Camaro with the LS1 engine. It smokes blue "sometimes" on start up. When you step on it, you get a puff of blue, but it goes away.
I've put a catch can on it, so ruled out the PCV. I haven't done a compression test, so not sure on that yet. What has me confused is on start up. If it was the valve seals, wouldn't it smoke everytime? If if was a ring problem, wouldn't it smoke steadily on WOT?
Thanks in advance....
Excellent forum!!!
Old Jul 27, 2010 | 02:47 PM
rwb's Avatar
rwb
It could be a little oil puddling up in your cylinders. Of course it could be your rings or valves biting it.
Old Jul 30, 2010 | 07:43 AM
AL SS590 M6's Avatar
Moderator
Excellent forum!!!
How much oil does it use,qts per 1000 miles?
Old Sep 4, 2010 | 02:53 PM
bts's Avatar
bts
Thanks all. Finally did a compression test. It's looking like rings in cylinder 1. All the other cylinders are 155-160. Cylinder 1 is 105, then oil added it bumps to 120. It's starting to use oil now.
So, what do you guys recommend? Can i just replace rings in one cylinder if no other damage? Should I put piston and rings in all? I'm at around 96K miles. What else should I replace if I'm in there?
Not sure of the dollars I'm looking at. Is it going to potentially cost as much as a crate LS1 $2700??
Recommendations?
Thanks again all.....
Todd
Old Sep 5, 2010 | 02:28 PM
8cylinders>4's Avatar
Recommendations?
Todd
we need a little more history on the car, it doesn't seem feasible to me that your valve seals or rings can be shot already with such low miles unless its been run ragged all its life. Do you spray it? Large cam?
Old Sep 22, 2010 | 05:38 PM
bts's Avatar
bts
Update for everyone. I ended up getting a good deal on a used LS1 with low miles. Couple of questions. The LS1 I purchased was from a standard trans car, I have an automatic. What do I need to do? Do I swap wiring harnesses from engine to engine to continue to use my automatic or are there other options? I'm thinking of selling the old LS1, what are your thoughts? Is it worth selling, if so, how much should I ask? The motor will need a bit of work, I'm thinking valve seals and possibly rings?
Thoughts?
Thanks,
Old Sep 23, 2010 | 06:39 AM
Moderator
yeah swap your auto harness on to the new motor.
Sell the old one as a rebuildable core. Don't know the value.
Alien
West South Central
Jan 11, 2015 12:51 PM
5.7L 00 SS
Aug 6, 2002 07:01 AM
5.7L 00 SS
Aug 4, 2002 06:26 PM
Mad_Ice
Jul 29, 2002 09:44 PM
2000silverz28
Jul 20, 2002 06:14 AM
