difficultly/length of time manifold gasket
Old May 27, 2010 | 08:35 PM
TA6.66LITRE's Avatar
for a 2000 z28 a4. drivers side. How long will it take on average. What is involved? and is it difficult in you opinion
Old May 27, 2010 | 11:46 PM
GhostZ28's Avatar
If its the exhaust manifold gasket, then it shouldn't take you longer than 2 hours with just two or three sockets and extensions (flex's help). leave the bottom/ypipe bolted up, just remove all bolts, and slip the new one in.
If you're doing an intake manifold gasket, all sides need to be done because you get a new set and they are re-useable so just put in the new ones all around. If you've never done an intake manifold before it will probably take you a few hours, but usually an hour or hour and a half.
Old May 28, 2010 | 07:29 AM
Marc 85Z28's Avatar
The studs that attach the Y-pipe to the manifold will most likely break off.
Why are you replacing the exhaust manifold gasket? They NEVER fail.
Old May 28, 2010 | 01:55 PM
exhuast manifold gasket. it seems to be leaking. and when i turn a/c on it seems like my exhuast is vibrating
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
Snoman73
Nov 17, 2014 07:22 PM
